Domains not applicable in nonisothermal flow module in time dependent conjugate heat transfer simulation
Posted 18 set 2017, 18:28 CEST General, Heat Transfer, Geometry Version 5.3 3 Replies
Hi all,
I am simulating a coolant going through a pipe, cooling down two bodies. First, the coolant goes inside a block, where there will also be air flowing inside. The air should be cooled down a bit by this first block. Then the cooland continues to a plate, where it will circulate in a snake-like shape, before going out of the system.
I am using the Heat Transfer + Laminar Flow modules, couples with the nonisothermal flow Multiphysics module.
I have set two inlets boundary conditions (Laminar Flow module). One for the cooland and another for the air. I also have one outlet condition for the exit of the cooland and the air goes away from the box (I have a open boundary condition set on the boundaries of the air volume (cube) enclosing my box. There is also 2 temperature boundariy condition to set the temperature in the air and coolant inlets.
I don't know why but all my domains are as "not applicable" in the nonisothermal flow domains selection.
Can someone help me, please? I don't know what I am missing. The model is attached.
Thanks. Cheers, Mateus
-------------------_________________________________
PhD at Université de Genève & CERN
Genève, Switzerland
