Saving the geometry file
I am a beginner using COMSOL for practice I created a structure using geometry tool and saved it as.mph file but when I am trying to import the same model to analyse ,it is not showing the file in the saved path when I am browsing to import it. Could anyone please help me resolve this issue?
1 Reply Last Post 11 set 2017, 14:27 CEST
Posted: 8 years ago 11 set 2017, 14:27 CEST
Hello Sarika,
You can bring in all the steps that were taken to create a geometry contained in an existing .mph file by using "Insert Sequence".
If you do not want all the steps but just the final geometry, "Export" the geometry out of the old file as a .mphbin file. You can then "Import" it into the new file.
Hello Sarika, You can bring in all the steps that were taken to create a geometry contained in an existing .mph file by using "Insert Sequence". If you do not want all the steps but just the final geometry, "Export" the geometry out of the old file as a .mphbin file. You can then "Import" it into the new file. Best, Jeff
