Modeling Piezoelectric Devices in 2D (Quartz)
Hello all,
I'm trying to model a AT-cut quartz in 2D. I have no problem working in 3D (similar to the thickness shear oscillator example: www.comsol.com/model/thickness-shear-mode-quartz-oscillator-4707), but something about the choices of coordinate systems in 2D is throwing me off.
In 3D i use a Euler angle (ZXZ) of (0,-54.75,0)[deg] with the LH IEEE 1978 material properties and my simulations have the desired results. In this simulation my quartz is a cylinder with the thickness in the global Z-direction, just like the previously mentioned example.
In moving to a 2D simulation, I want to capture the shear deformation that is in the X direction on a cross section of the crystal. I'm strugging getting the material orientation correct without use of the 3D Euler angles. Any assistance would be greatly appreciated.
2 Replies Last Post 30 ago 2017, 14:29 CEST
Posted: 8 years ago 29 ago 2017, 18:28 CEST
Hi there,
to my knowledge it is not possible orient the materials in 2D simulations.
Anyway, you could calculate the rotate tensors and create a new material.
Hi there, to my knowledge it is not possible orient the materials in 2D simulations. Anyway, you could calculate the rotate tensors and create a new material.
Posted: 8 years ago 30 ago 2017, 14:29 CEST
I had thought that might be the only way to go about this. Thank you for your response
-Brandon
I had thought that might be the only way to go about this. Thank you for your response -Brandon
