Using 'if' statement with two conditions
I want to use and if statement in COMSOL but I need it to have two conditions.
I want to calculate the value of the x coordinate when y = 0 and T=300.
Something like:
if(y ==0 and T == 300, xi == x)
Would the AND logical operator (&&) work instead of the and in my above statement?
No matter what I try I get errors.
Someone mentioned in a previous post that my if statement must not contain discontinuities and that they can be avoided by combining the if and sens operators, I don't understand how to do this though.
I would really appreciate some help with this problem!
-Adam.
7 Replies Last Post 25 lug 2012, 08:09 CEST
Posted: 1 decade ago 11 mar 2011, 14:13 CET
the discontinuity issue is when you use such Dirac functions for the physics, then the solver might "jump over them"
perhaps if you use more (), or try a boolean
(x==0)*(T==300)*YourValue
Hi the discontinuity issue is when you use such Dirac functions for the physics, then the solver might "jump over them" perhaps if you use more (), or try a boolean (x==0)*(T==300)*YourValue -- Good luck Ivar
Posted: 1 decade ago 11 mar 2011, 15:56 CET
Hi Ivar,
Thanks for the quick reply.
I understand what you are saying.
However I wish to assign the variable xi to the value of x when T=300 and y=0.
So that if both T=300 and y=0 are true (then equal to one) then whatever the x coordinate at the point is gets assigned to xi.
If I use the expression you suggested then xi comes back with a value of 0.
I am trying to use an if statement to get the value I want but keep getting a value of 0 for xi:
if(T==300 && y == 0,xi == x)
I hope I have made my problem clear!
I would really appreciate some help!
-Adam
Hi Ivar, Thanks for the quick reply. I understand what you are saying. However I wish to assign the variable xi to the value of x when T=300 and y=0. So that if both T=300 and y=0 are true (then equal to one) then whatever the x coordinate at the point is gets assigned to xi. If I use the expression you suggested then xi comes back with a value of 0. I am trying to use an if statement to get the value I want but keep getting a value of 0 for xi: if(T==300 && y == 0,xi == x) I hope I have made my problem clear! I would really appreciate some help! Thanks, -Adam
Posted: 1 decade ago 11 mar 2011, 17:06 CET
then what about:
Your_value = (y==0)*(T==300)*(My_New_Value - Some_other_value) + Some_other_value
Hi then what about: Your_value = (y==0)*(T==300)*(My_New_Value - Some_other_value) + Some_other_value -- Good luck Ivar
Posted: 1 decade ago 11 mar 2011, 23:56 CET
There are some descriptions about the if operator in the User's Guide. It said the expression is if(cond, expr1, expr2), I am not sure whether expr2 is necessary or not. You can see the Guide for details.
Posted: 1 decade ago 12 mar 2011, 10:36 CET
there are two places whree aou can test out formulas:
- the parameter line that calcualtes out your value (and translates the units)
- the analytical function, whcih allows you quickly to plot a function. I mostly write my complex fomulas as functions, as then I can plot them easily to check how they look, its so easy to forget a sign, or an offset. Alwaysmverify and validate your work,in steps it's easier ;)
Hi there are two places whree aou can test out formulas: - the parameter line that calcualtes out your value (and translates the units) - the analytical function, whcih allows you quickly to plot a function. I mostly write my complex fomulas as functions, as then I can plot them easily to check how they look, its so easy to forget a sign, or an offset. Alwaysmverify and validate your work,in steps it's easier ;) -- Good luck Ivar
Posted: 1 decade ago 25 lug 2012, 02:52 CEST
Are there any way to make a 2D function?
I can easily plot the function f=(x<= 5).
But how to plot a function f=(x<=5,y<=5) in a 2D plan.
Cheers,
Dao
Are there any way to make a 2D function? I can easily plot the function f=(x
Posted: 1 decade ago 25 lug 2012, 08:09 CEST
have you tried the filter and (x<5)*(y>2) condition, or whatever Boolena condition you need ?
Hi have you tried the filter and (x2) condition, or whatever Boolena condition you need ? -- Good luck Ivar
