Opticaly modulated laser - Tissue interaction
Hi there ..
I am trying to investigate the frequency modulated laser effect on tissue. I am modulating the laser from 0 -1GHz. and trying to see the insertion and phase loss with certain seperation of laser to photodiode? can this be done in comsol? So i have a laser with certain wavelength that is frequency modulated and a photodiode, both been apart with certain dictance and the media is a human tissue. looking for how much modulated photons i am going to receive and whats their phase information. !!!!
Ebrahim
3 Replies Last Post 2 mar 2011, 08:24 CET
Posted: 1 decade ago 1 mar 2011, 22:08 CET
A challenging model you need there !
I would rather ask myself what is giving amplitude and phase shift of the laser beam on its way trough your tissue ?
If you can express this with a PDE + material data properties with their wavelength and illuminted power relation, then I believe you should be able to feed that into COMSOL.
But if not, then I do not believe COMSOL can give you new inputs, as its basically "only" a powerful numerical solver of PDEs and ODEs so you need to express the physical phenomena first.
Hi A challenging model you need there ! I would rather ask myself what is giving amplitude and phase shift of the laser beam on its way trough your tissue ? If you can express this with a PDE + material data properties with their wavelength and illuminted power relation, then I believe you should be able to feed that into COMSOL. But if not, then I do not believe COMSOL can give you new inputs, as its basically "only" a powerful numerical solver of PDEs and ODEs so you need to express the physical phenomena first. -- Good luck Ivar
Posted: 1 decade ago 1 mar 2011, 23:00 CET
Hi Ivar
Yes i can module the diffusion equation (boltzman Transport) through PDE using helmholtz equation, but i am not sure how to set the input as a laser beam of modulated photons? and then read the s-parameter in both phase and magnitude?
How far can you help in this?
Ebrahim
Hi Ivar Yes i can module the diffusion equation (boltzman Transport) through PDE using helmholtz equation, but i am not sure how to set the input as a laser beam of modulated photons? and then read the s-parameter in both phase and magnitude? How far can you help in this? Thanks Ebrahim
Posted: 1 decade ago 2 mar 2011, 08:24 CET
unfortunately no, it's too extensive, I have a full time job using COMSOL and my presence here is only on private time, so I restrict myself to short question/answers. Furthermore I have dropped 3.5 now, too much work to use both systems, and 4.1 is very good, and far easier/quicker to use.
It's a nice project though
Hi unfortunately no, it's too extensive, I have a full time job using COMSOL and my presence here is only on private time, so I restrict myself to short question/answers. Furthermore I have dropped 3.5 now, too much work to use both systems, and 4.1 is very good, and far easier/quicker to use. It's a nice project though -- Good luck Ivar
