Memory Problems with Magnetic Field Shielding Simulation
Posted 17 apr 2017, 16:13 CEST Low-Frequency Electromagnetics, Mesh Version 5.2a 0 Replies
I am working currently on a simulation designed to test the effectiveness of a magnetic shielding system. The simulation has the following elements:
• Simulation volume: cylinder with a diameter of 805 mm and a height of 1645 mm
• Magnetic dipole
• Two paramagnetic concentric cylindrical shells of height 470 mm, inner diameters of 85 mm and 92 mm respectively, and 0.5 mm thickness, with magnetic permeability mur = 250000
The dipole is the source of the field and the paramagnetic shells constitute the shielding system. The solver calculates the magnetic field in the entire simulation region. The problem does not have a rotation symmetry due to the chose dipole position and orientation.
The problem I am having is that the computer is running out of memory as I am conducting a mesh convergence test. In an attempt to solve this, I tried to roughly calculate how much memory on average an element would take in an attempt to calculate the ram I would need to run my simulations. I ran one test with 1.5e6 total domain elements and 8.5e6 degrees of freedom. This simulation seemed to peak at around 14-15 GB when the meshing was being created. That would mean that on average each tetrahedron would need around ~1000 bytes per degree of freedom.
I am confused as to why this number is so high per degree of freedom.
Any insight on this issue would be much appreciated,
Thank you
Hello Dinindu Gunasekara
