error while solving..
I am using v5.0 and I am having this error. My model solves for heat transfer, fluid flow, and vapor transport. Any help would be very appreciated.
Thanks!
Jessica
Division by zero.
- Function: /
- Expression: nojac(((1.4142135623730951^(1-shapeorder(comp1.cv)))*max((((sqrt(comp1.tds.gugijgu_cv)*((0.5*abs(comp1.tds.Res_cv))*comp1.tds.xiu_cv))/((comp1.tds.gugijgu_cv+((h^2)*sqrt(eps)))*comp1.tds.epsilon_p))-(((comp1.tds.Res_cv^2)*comp1.tds.tauScCwd_cv)/(eps+(comp1.tds.gugijgu_cv*comp1.tds.epsilon_p)))),0)))
Failed to evaluate temporary symbolic derivative variable.
- Variable: comp1.tds.crosswind@VDN${test@92}@VDN$comp1.cvz
- Defined as: (((-nojac(((1.4142135623730951^(1-shapeorder(comp1.cv)))*max((((sqrt(comp1.tds.gugijgu_cv)*((0.5*abs(comp1.tds.Res_cv))*comp1.tds.xiu_cv))/((comp1.tds.gugijgu_cv+((h^2)*sqrt(eps)))*comp1.tds.epsilon_p))-(((comp1.tds.Res_cv^2)*comp1.tds.tauScCwd_cv)/(eps+(comp1.tds.gugijgu_cv*comp1.tds.epsilon_p)))),0))))*comp1.tds.epsilon_p)*comp1.tds.gijyz)
- Expression: d(d((comp1.tds.crosswind*(comp1.isScalingSystemDomain==0))*(dvol),{test@92}),comp1.cvz)
- Feature: Time-Dependent Solver 1 (sol1/t1)
1 Reply Last Post 9 apr 2017, 23:14 GMT-4
Posted: 9 years ago 9 apr 2017, 23:14 GMT-4
Hi Jessica
You probably have used the results of a previous study as the initial condition, which has been solved with different mesh configuration.
Try to use the same mesh for both.
If you have not done so, delete the whole study and define a new one.
Amin,
Hi Jessica You probably have used the results of a previous study as the initial condition, which has been solved with different mesh configuration. Try to use the same mesh for both. If you have not done so, delete the whole study and define a new one. Amin,
