                                29 gen 2011, 21:30 GMT-5
                                                    Do you get a solution without enabling it?
The solver should return an error fairly early if the only problem is geometry nonlinearity. In that case, just check the box and re-run.
If you are still not getting a solution with nonlinearity enabled, I would recommend experimenting with solver settings.
It is likely for large deformations that you are going to need an iterative solve with a pre-conditioner.
                                29 gen 2011, 23:11 GMT-5
                                                    I am getting a solution with the nonlinearity "unchecked' but I still don't understand when I am supposed to "check" the geometric nonlinearity. My problem is nonlinear but I don't know the functionality of geometric nonlinearity.
From what I read in the manual, geometric nonlinearity is the same as enabling large deformations. I am still not sure in what case should I use large deformations/geometric nonlinearity.
Thanks for the help.
Sirisha
PS: I am having convergence issues with this option checked.
Sirisha
                                30 gen 2011, 03:50 GMT-5
the large deformation changes the equations used for the stress-strain relationship (see the doc), this adds a cross derivative term (note: large deformations are incompatibile with Antisymmetry BC conditions, be warned).
The simplest way around is to make a run without, and one with, and compare the results.
But if you are in structural or fluide-structure interaction FSI, and in artery analysis, I would rather expect to have it turned on (which means slower solving nad more calculations)
                                30 gen 2011, 16:50 GMT-5
                                                    Thanks Ivar!
I think I have an idea now .......it needs to be turned on for my case but the problem is that if I turn on the geometric nonlinearity, the problem does not converge. There may be other things that I have to try to make the problem converge.
Thanks once again,
Sirisha
                            Thanks Ivar!
Thanks once again,
Sirisha
                                30 gen 2011, 17:20 GMT-5
if you have a fuid flow case, often the default initial conditions of "0" are giving trouble, you could set some average velocity (parabolic profile) and pressure drop (i.e Poiseille) to help the system to start. then if you use only velocity, define an absolute pressure somewhere on a point, to fix the gauge pressure
                                30 gen 2011, 23:27 GMT-5
                                                    I will use a fluid flow but that's only after I have a successful run with the current case. In the current problem, all I have is a hollow pipe (this is my solid mechanics module) and I am applying a pressure on the internal boundaries. So its just a pressure applied hollow pipe that I expect to expand radially and contract longitudinally. Unfortunately the problem is not converging when I use a hyperelastic model. It also does not converge when I use a linear elastic model with the nonlinear geometry checked.
Sirisha
Sirisha
                                31 gen 2011, 15:58 GMT-5
                                                    I am wondering if someone can tell me why the attached problem is not converging.  I am not very familiar with the solid mechanics part of COMSOL so I am not sure what the problem is missing that will help it converge. Are my boundary conditions wrong?
Sincerely,
Sirisha
Sincerely,
Sirisha
                                1 feb 2011, 03:17 GMT-5
I believe its because you "hit" it too hard: you start your simulation at rest, no stress, all "0" and in the next instant you apply 4 bars pressure.
That is tough for the poor solver ;)
Try a continuation sweep with a parameter and ramp your load in 10 or more steps.
Then by forcing one "point " fixed + 1 symmetry plane you create singularities, I would rather propose to block, by opposed pairs, all 8 points (or at last the 4 externals) on your symmetry plane with y=0 and the two vertical ones with z=0 (Prescribed constraints).
Or you do it fancier, by creating a coupling variable and resolve it to have the central average section center to remain on Y=0,Z=0 and you force no twist (Rx)
Finally if your case is fully symmetric, you could use 3 symmetry planes, which reduces by 4 the number of elements, and blocks the system on axis
                                1 feb 2011, 16:54 GMT-5
                                                    He he :) I though COMSOL does some magic for me and things will work out when I have the right physics :)
Thanks for the valuable knowledge.
I am trying the parametric sweep now and its running. I am doing 0:5:40000Pa. So I expect it to get done in 2-3 days :)  Before that I tried with a pressure of 2Pa instead of 40,000 and it worked!
I also tried the 4 externals with the prescribed displacement of y=0 and z=0(vertical points) and the problem converges faster (provided the pressure is still 2Pa). But the result I am seeing with this scenario is not what I want. When I apply the pressure, I want the inlet face to stay where it is while the rest of the pipe expands radially and contracts longitudinally. I am not sure how to simulate this. I did the fixed constraint based on what I saw in a COMSOL tutorial. If you have any ideas about how to achieve this result then please let me know.
Also...........you wrote that "Or you do it fancier, by creating a coupling variable and resolve it to have the central average section center to remain on Y=0,Z=0 and you force no twist (Rx)". I don't know how to create a coupling variable and I am looking through the user manual but am not able to locate any information on this. Can you please provide me with more hints or directions on where I can locate more information on how to create coupling variables.
I tried incorporating symmetry (in which case I consider only half the geometry of what I attached earlier) but I am running into "failed to find a solution" error. I am not sure how to resolve this.
Thanks so much for the help.
Sincerely,
Sirisha
Sincerely,
Sirisha
                                2 feb 2011, 01:39 GMT-5
0:5:40000 is really small steps probably a 40000*range(0,0.1,1) would do
You can also fully fix the inlet tube section, but then it cannot expand, if you just block the external points so they can expand radially your system will solve and remain stable, without inlet shape artefact's (over-constrained surface)
It in the Define subnode you can find them, make very simple examples to begin with
full symmetry is possible (oups check it in the doc for your hyper elastic material there might be an incompatibility there, just as "large deformations are mostly incompatible with antisymmetric boundary conditions, but not symmetric)
Again take a simple case to start with
                                20 set 2013, 09:40 GMT-4
                                                    This function is not available in 4.3b version.
Solutions obtained with and without this function vary significantly. I dont how to locate this option in 4.3b version
