Setting a parameter to values from an imported table
Posted 7 feb 2017, 22:17 CET Simulation Apps Version 5.2 0 Replies
I have an application in which I currently import a file which is used to define an interpolation function. I would like to modify the method in which this file is imported so that I can also use some of the data in the file to change a couple of parameters. I thought that perhaps I could also import the file in to a table and then use the values in the table to create a string and assign it to my parameters. Does anyone know a way to do this? I essentially want the differences between the minimum and maximum values of the first two rows. The method currently looks something like this:
model.func("int1").discardData();
with(model.func("int1"));
set("filename", "C:\\Users\\ngoldring\\Comsol\\Models\\data_import.txt");
set("fp_length", "X");
set("fp_width", "Y");
endwith();
where X and Y are the values in which I would like to grab from the table. I was hoping to be able to take the cells that they fall in and just add them. Is it the case that I just need to write a piece of code that will do this? Thanks for any input!
Hello Nicholas Goldring
