28 gen 2011, 14:22 CET
Could itbe that you are in structural and that v and vt are already used by COMSOL ?
Always use "private names, most 1-2 letter names are already used by COMSOL, sometimes you want to redefine them, but often it gives errors, as you need to know exactly what you are doing
28 gen 2011, 14:26 CET
Thanks a lot for you reply.
I'm not using Structural. I have chosen ODEs and DAEs.
I have attached the Model.
I'd appreciate it if you could take a look.
29 gen 2011, 19:04 CET
you cannot try to solve for an ODE alone as you have not defined any dependent variables What is v ?, and vol1 ?
You need to define some physics via an PDE and possibly add an ODE if required
8 feb 2011, 16:25 CET
Ivar is right (of course!).
But you can in fact solve an ODE, as a global space independent problem. You to define the dependent variable, as Ivar points out, and you can do this by setting Name to v in the Global Equations settings, also, change vol1 to 0 or something else that is defined.
If you want to solve a distributed ODE on a 2D domain (where sources may change with position, but you have no gradient driven transport), use rather a General form PDE and only use the f and da terms.
Niklas
Niklas
