9 years ago
7 feb 2017, 18:40 CET
If you are using convective heat flux.. and changing ambient temperature. then you can use ambient temperature as a step function or else type this expression in ambient temperature field . if(t<heatingtime, T_hot, T_cold).
8 years ago
9 feb 2017, 04:50 CET
Thank you for your quick reply.
In the model, I am applying a heat source which is moving with certain velocity and heating the specimen, when i am defining the time study the heat source is running for the defined time and by that time only heating is happening which i don't want. I want to stop the heat source functioning after certain time to diffuse the heat. for this i have to define heating time and cooling time in same simulation.
Henrik Sönnerlind
COMSOL Employee
8 years ago
9 feb 2017, 08:40 CET
Maybe this blog post will give you some ideas:
https://www.comsol.se/blogs/how-to-make-boundary-conditions-conditional-in-your-simulation/
Henrik
8 years ago
9 feb 2017, 10:39 CET
Thank you for your response.
Sujit
Sujit
