Setting up 3-d Navier-Stokes using weak form pde
Posted 15 nov 2016, 20:31 GMT-5 Fluid & Heat, Modeling Tools & Definitions, Parameters, Variables, & Functions, Studies & Solvers Version 5.2 0 Replies
I am trying to set up 3-D navier-stokes equation for a fluid confined in a box, using weak form PDE , instead of the comsol predefined fluid flow module.
I eventually want to make one of the walls moving, so that the result is not trivial.
I was successful in making 2d model work, but when I did everything same for 3d, it gave me this error message:
Segregated Step 1
System matrix is zero.
- Feature: Time-Dependent Solver 1 (sol1/t1)
I've been looking around to seek solution to this, but there weren't any consistent answer to this problem. Could it be the solver issue, where I need to set up the solver in some different way?
Several notes on how I set up the simulation (both in 2d and 3d):
- 2 weak form PDEs: momentum (velocity), and continuity(pressure)
- Dirichlet boundary condition on all the walls for momentum
- Pointwise constraint on the continuity (pressure) equation
- Initial conditions all zero
- Allowed discretization, function type: Lagrange, quadratic for velocity, and linear for pressure.
Attaching both my 2d and 3d models.
Thanks!
Hello Jong Woo Nam
