calling up a varible defined by program
Elizabeth Van Heusden
I am trying to plot a function prior to solving the model that involves a the variable H(for magnetic fields) and it fails to recognize it. Currently the syntax is mfnc.normH which is used else in the program. Is this possible or not?
1 Reply Last Post 24 ott 2016, 10:07 CEST
Magnus Ringh COMSOL Employee
Posted: 9 years ago 24 ott 2016, 10:07 CEST
If the variable name is correct it should work, but if you want to plot and postprocess such variables before you have computed a solution, right-click the Study node and choose Get Initial Value to make the dependent variables available as solutions using their initial values. Otherwise, their values are undefined.
Magnus Ringh, COMSOL
Hi, If the variable name is correct it should work, but if you want to plot and postprocess such variables before you have computed a solution, right-click the Study node and choose Get Initial Value to make the dependent variables available as solutions using their initial values. Otherwise, their values are undefined. Best regards, Magnus Ringh, COMSOL
