Best way to calculate flowrate?
Hi all,
For fluid flow through a pipe I am currently calculating flowrate by integrating the component of velocity orthogonal to the inlet/outlet over the inlet/outlet surface. For my flow in z-direction my inlet flowrate (my inlet is orthogonal to the z-direction) is the surface integral of w (the z-component of velocity) over the inlet.
Is there an alternative way to calculate flowrate? Perhaps a default option for calculating flowrate when using the CFD module?
Cheers
5 Replies Last Post 13 gen 2011, 20:03 CET
Posted: 1 decade ago 10 gen 2011, 09:52 CET
not what I know about (but I do not say I know everything, particularly not in CFD) but what is wrong with integrating velocityover the inlet/outlet area ?
Hi not what I know about (but I do not say I know everything, particularly not in CFD) but what is wrong with integrating velocityover the inlet/outlet area ? -- Good luck Ivar
Posted: 1 decade ago 10 gen 2011, 16:17 CET
I was just wondering if this information was automatically created somewhere else in COMSOL, especially for flow through an open system. I have also run some more complicated geometries and noted slight (1-2%) differences in flow rate at inlet and outlet and wondered if that discrepancy was impacted by the accuracy of the surface integral.
Cheers, Nathan
I was just wondering if this information was automatically created somewhere else in COMSOL, especially for flow through an open system. I have also run some more complicated geometries and noted slight (1-2%) differences in flow rate at inlet and outlet and wondered if that discrepancy was impacted by the accuracy of the surface integral. Cheers, Nathan
Posted: 1 decade ago 11 gen 2011, 07:50 CET
flow rates , or in general any integration is done on the mesh ndoes with shpae function developments, so if you have a dense mesh you will get a more precise value. Anhow, for me FEM is 3-5% precise in most cases, to get < 1% you need a looot of RAM and tiiiime ;)
Hi flow rates , or in general any integration is done on the mesh ndoes with shpae function developments, so if you have a dense mesh you will get a more precise value. Anhow, for me FEM is 3-5% precise in most cases, to get < 1% you need a looot of RAM and tiiiime ;) -- Good luck Ivar
Posted: 1 decade ago 13 gen 2011, 19:18 CET
Just curious...
If you are running a CFD flow problem what is your preferred choice of solver/solver settings?
I have a little bit of RAM at my disposal (24GB) and have been using a direct solver (mostly because I had trouble with the default settings for the iterative solver the first time I used the CFD module).
Nathan
Just curious... If you are running a CFD flow problem what is your preferred choice of solver/solver settings? I have a little bit of RAM at my disposal (24GB) and have been using a direct solver (mostly because I had trouble with the default settings for the iterative solver the first time I used the CFD module). Nathan
Posted: 1 decade ago 13 gen 2011, 20:03 CET
I usually use the default values in my patched 4.1.0.112
Hi I usually use the default values in my patched 4.1.0.112 -- Good luck Ivar
