26 dic 2010, 20:41 CET
if you read the doc on RF for v4.1 you will get a rather ind epth explanation I believe:
in very short:
A BOUNDARY "port" or a "scattering" condition are to define absorbing/source electric boundaries, in a distributed or a lumped (port) , but in well defined way, this means among other that the wave can travel in both direction from or through the boundary.
While the PML is a DOMAIN feature simulating an infinite domain where ANY wave can propagate and dissapear (without being reflected back)
in very short:
13 gen 2011, 00:01 CET
Sir
If I want to caculate the Q factor of the whispering gallery mode in the 2D optical circular disk microdisk, what kind of boundary condtion shall I use? The Q factor is just limited to the radiation if I dont consider the absorption of the material .
Another question is shall I use the eigenfrequency analysis to calculate the eigenvalue? After that ,I chose the eigenvalues with small real parts(which with high Q) and calculate the Q factor in the which the imaginary part is divided by the real part. Is the method correct?
Thank you
in very short:
Sir
Thank you
[QUOTE]
in very short:
[/QUOTE]
