3D plotting normal displacement on surfaces
Posted 8 set 2016, 14:21 GMT-4 Geometry, Mesh, Results & Visualization 2 Replies
When doing a 3-D plot, I want to illustrate how a c-library function I wrote, designed to generate rough surfaces via the Deformed Geometry (dg) module. I want to plot contours of the normal component of the displacement.
The displacement, defined over volumes, is : dg.dxx, dg.dyy, dg.dzz
The normal unit vector, defined (of course) over surfaces, is: dg.nXg, dg.nYg, dg.nZg
What's wanted is the dot product... but this requires sampling dg.dxx, etc, on the surface, where at present it is undefined.
Any hints?
Here's a plot of my surface, showing only dg.dxx, which is what I want only on faces normal to x-hat:
i.imgur.com/7EAVI4Z.png
Any hints?
2 Replies Last Post 16 set 2016, 15:10 GMT-4
