Hello Noritaka Yusa
28 lug 2011, 21:50 CEST
Thanks to Noritaka, here is one solution:
Here is a way to get the data of table under the matlab environment.
the syntax is "a=model.result.table('tbl1').getReal or b=model.result.table('tbl1').getImag"
here "a" and "b" are the variables of matlab which are defined by yourself.
The value of the table is a complex.
I also found out how to save a table as .txt or .xls files , namely:
model.result.table(minaTbl).save(['C:\...\comsolLivelink\' Tbl '.txt']);
model.result.table(minaTbl).save(['C:\...\comsolLivelink\' Tbl '.xls']);
Hope it helps.
Mina
Hope it helps.
Mina
20 giu 2012, 11:22 CEST
hello
i have the same problem but it's about the result ,thanksgiving
instead of having a table of 4 columns I found a table with two columns of false data as you can see in the atach file
hello
