29 dic 2010, 08:24 GMT-5
for example, search at internet for:
cross-section for impact electron with N2+
next use form profiles of " cross-section electron impact with N2+"
parviz
[QUOTE]
parviz
Daniel Smith
COMSOL Employee
29 dic 2010, 10:08 GMT-5
Hi, cross section data can be found here:
www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php
The file needs to be modified slightly before it can be imported into COMSOL. The user's guide explains the required format.
/ Dan
http://www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php
/ Dan
17 gen 2011, 06:32 GMT-5
Hi Daniel,
What was the source used for the ionization cross sections for the Argon metastable used in the model library ie. e+Ars=>2e+Ar+ - I cannot find this information on the University of Toulouse electron scattering database -
www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php.
Kind Regards,
Sean
Hi Daniel,
What was the source used for the ionization cross sections for the Argon metastable used in the model library ie. e+Ars=>2e+Ar+ - I cannot find this information on the University of Toulouse electron scattering database - http://www.lxcat.laplace.univ-tlse.fr/cross_sec_download.php.
Kind Regards,
Sean
15 nov 2013, 09:38 GMT-5
Hello Daniel,
I am simulating nitrogen dc plasma for DBD reactor in dc discharge interface. I used database from Phelps for nitrogen cross section. For importing nitrogen database to COMSOL, it needs "statistical weight ratio" of final state to initial state (as 2nd number of 3rd line). I tried to search, but could not find this number for nitrogen excitation reactions.
Could you please help me, by sharing the source/reference to these values or procedure how to calculate them?
I would like to thank you in advance. Looking forward to hear from you.
Best Regards,
Bhaskar
Hello Daniel,
Best Regards,
Bhaskar
9 set 2014, 02:29 GMT-4
I meet the same problem with you, how do you deal with this question finally?
14 mar 2015, 10:59 GMT-4
Have you found the solution?
Best regards.
Best regards.
9 years ago
18 apr 2017, 04:11 GMT-4
I HAVE THE SAME PROBLEM. HAS anyone solved?
