Solution not computed error message
Please, what can cause this error "Solution 1 is not computed"?.
2 Replies Last Post 19 lug 2016, 09:18 CEST
Posted: 9 years ago 19 lug 2016, 09:09 CEST
The full error message is
Solution 1 is not computed.
- Feature: Dependent Variables 1 (sol1/v1)
The full error message is Solution 1 is not computed. - Feature: Dependent Variables 1 (sol1/v1)
Posted: 9 years ago 19 lug 2016, 09:18 CEST
I am running a turbulent flow through a long pipe; having several inlets. The domain has both outer and inner wall boundaries, with no-slip conditions; It is a time dependent problem.
Any suggestion will be appreciated.
I am running a turbulent flow through a long pipe; having several inlets. The domain has both outer and inner wall boundaries, with no-slip conditions; It is a time dependent problem. Any suggestion will be appreciated.
