Easy way to flip the coordinate axis of my model.
Hi there guys, my model currently has the y-axis pointing in the direction that I would like to have the z-axis pointing. Does anyone know of an easy way to do this without going through each component of my model and changing the orientation? Thanks a bunch!
7 Replies Last Post 24 giu 2016, 21:23 CEST
Posted: 9 years ago 10 giu 2016, 22:31 CEST
I am not sure I understand what you are trying to achieve, but have you looked into the Component > Definitions > View nodes? You could create a view with the up vector you need and then apply that view to all necessary plots.
I am not sure I understand what you are trying to achieve, but have you looked into the Component > Definitions > View nodes? You could create a view with the up vector you need and then apply that view to all necessary plots. Jeff
Posted: 9 years ago 10 giu 2016, 22:35 CEST
Thanks again for the response Jeff. What I mean is that I would like to work in a space, build the geometries, examine the plots etc all in a different coordinate system where the z direction would be going in the current y direction. I guess I should have originally built my geometries that way, it is just easier for me to bring in outside data and tie my project in to others if I can flip these axes.
Posted: 9 years ago 10 giu 2016, 22:42 CEST
Actually I think a rotational transformation of my entire geometry will solve this problem.
Posted: 9 years ago 10 giu 2016, 22:48 CEST
This at least worked in the geometry workspace but the axis is still off in my plots, I guess I can just change views.
[QUOTE] Actually I think a rotational transformation of my entire geometry will solve this problem. [/QUOTE] This at least worked in the geometry workspace but the axis is still off in my plots, I guess I can just change views.
Posted: 9 years ago 11 giu 2016, 09:03 CEST
Have you tried to define a new "Definition View", then orient that one (either with the mouse or with the numerical values in the tab), then hit the Lock coordinates check button of the View node.
Later, by keeping this view the default (green rectangle in the icon in the model tree) you select in the graphical view icon the desired View and your screen image is oriented as desired (also the Zoom factor)
Hi Have you tried to define a new "Definition View", then orient that one (either with the mouse or with the numerical values in the tab), then hit the Lock coordinates check button of the View node. Later, by keeping this view the default (green rectangle in the icon in the model tree) you select in the graphical view icon the desired View and your screen image is oriented as desired (also the Zoom factor) -- Good luck Ivar
Posted: 9 years ago 15 giu 2016, 18:54 CEST
Exactly what I needed to do. Thank you!
[QUOTE] Hi Have you tried to define a new "Definition View", then orient that one (either with the mouse or with the numerical values in the tab), then hit the Lock coordinates check button of the View node. Later, by keeping this view the default (green rectangle in the icon in the model tree) you select in the graphical view icon the desired View and your screen image is oriented as desired (also the Zoom factor) -- Good luck Ivar [/QUOTE] Exactly what I needed to do. Thank you!
Posted: 9 years ago 24 giu 2016, 21:23 CEST
Just an FYI, for it to have worked in your plots you would have to resolve the model, and then this should have worked for you.
