Hello Johan Gustafsson
28 dic 2010, 03:34 GMT-5
Did you figure it out?
4 gen 2011, 13:35 GMT-5
No, unfortunately I have not. I worked around the problem by calculating the variables in MATLAB first and then assigning the final value to the COMSOL model. But it would still be nice to be able to get this to work.
Johan
Johan
21 dic 2011, 06:38 GMT-5
If I have a parameter, e.g.:
>> model.param.set('outer_z', '((volume*formfactor^2)/(2*pi))^(1/3)');
How can I in the easiest way evaluate the value of this parameter (like the 'Value'-column in the GUI)?
I get an error message when trying to use:
>> mphglobal(model,'outer_z')
"com.comsol.util.exceptions.FlException: Unknown dataset feature"
Johan
The function mphglobal(model,'parameter_name') works for me when calculating parameter values. Maybe there is a problem in your definition of ((volume*formfactor^2)/(2*pi))^(1/3), check that all the parameters are set.
Bye.
[QUOTE]
Johan
[/QUOTE]
Bye.
Andrew Prudil
Nuclear Materials
12 apr 2013, 13:07 GMT-4
Hi everyone,
Sorry for bring back such an old discussion but I'm having the same problem (unknown data set). I think this problem somehow relates to having not initialized the model (but I'm not sure how). Since it cannot find a dataset to evaluate the string in. Anyone know what I'm missing? Consider the simple striped down MATLAB script below which returns the same error. Interestingly enough model.param.get('test_param_a') will return the original string.
Thanks in advance,
Andrew
import com.comsol.model.*
import com.comsol.model.util.*
model = ModelUtil.create('Model');
model.modelPath('F:\FAST\MATLAB');
model.modelNode.create('mod1');
model.geom.create('geom1', 2);
model.geom('geom1').axisymmetric(true);
model.mesh.create('mesh1', 'geom1');
model.param.set('test_param_a', '1[mm]');
temp = mphglobal(model,'test_param_a')
Hi everyone,
Thanks in advance,
Andrew
10 mar 2014, 13:16 GMT-4
Johan
I'm also having the same problem, has anyone figured this out?
Mark
[QUOTE]
Johan
[/QUOTE]
Mark
Andrew Prudil
Nuclear Materials
10 mar 2014, 13:41 GMT-4
It has been a while since I worked with the LiveLink for Matlab. To get a parameter (pellet_length) from Comsol to Matlab I used the following commmand:
pellet_length = mphevalglobalmatrix(model,'pellet_length');
Not sure if this applies only to parameters, or if there is a better way of doing this, but it worked for me.
10 mar 2014, 16:01 GMT-4
Andrew. Thanks a lot! It turns out that I was able to get
to work too. So it appears I'm in good shape now.
Thanks!
Mark
[QUOTE]
[/QUOTE]
Thanks!
Mark
2 ott 2015, 05:19 GMT-4
model.param.get('outer_z') should work
