29 nov 2010, 06:56 CET
Hi Nick,
I have been trying to do almost the exact same problem but have not had any luck. I too feel like there must be a way to model a section (or turn) of the toroid rather than the whole structure. And like you I have been trying to implement it with periodic boundary conditions and extrusion coupling but have not got it to work.
Have you had any luck? Any insight that you can share?
George
Hi Nick,
George
29 nov 2010, 18:48 CET
Hi George,
I did make a bit of progress on this. After some more discussions with the Comsol staff, I ended up using boundary extrusion coupling variables to make the toroidal periodicity that I wanted.
Here is the general idea:
(1) Create a geometry that includes 2 periods in your torus
(2) Embed a 2D plane in the middle of that 3D geometry (between the first and second period) in order to have access to an internal boundary plane
(3) In the boundary extrusion coupling variables menu, select the middle boundaries as your source and create extrusion variables with the necessary rotation. Select the two end boundaries as your destination.
(4) In physics->boundary conditions, set the toroidal boundaries of the torus to your extrusion coupling variables. In my case I was interested in the magnetic vector potential, so I set the boundary condition to "Magnetic Vector Potential" and then set the values equal to my extrusion coupling variables.
Hope this makes sense. I do not know if this is the most elegant solution, and it does require 2 periods, but it is a lot better than building the whole torus. It seems to work for me. Let me know if you need a clearer explanation.
Nick
Hi George,
Nick
30 nov 2010, 21:11 CET
Hi Nick,
Thanks for the detailed tips. I have one more question regarding a 3D toroid.
How do you set an exciting input current into such a system for the two turns? You do not have access to the the turn boundaries because they are set as "Magnetic Potential" boundary extrusion couplings.
George
Hi Nick,
George
25 ago 2011, 18:32 CEST
Hi, I would like to understand this as well. I am creating something of a toroidal inductor and would like to model only a section (or I guess 2 as you stated) to reduce the load on memory and such. I have done what you suggested up to step 3. This is where i get lost. Where exactly do you find this "boundary extrusion coupling variables" menu? And how do you go about creating these extrusion variables. Thanks for the help ahead of time.
~Brock
~Brock
7 ott 2011, 14:27 CEST
I have one structure, and i want to calculate the repetion of this structure on one metter, in this case, how can I use periodicity
