to extract particle coordinates from particle tracing plot..
Hi..
I am using comsol 3.4 with matlab.
I want to know, if it is possible to extract the coordinates of a particle after tracing its path using particle tracing.
i am using postplot to obtain the trace. i want to know the x and y coordinates for a given z. any help will be highly appreciated.
its urgent.
thanx
5 Replies Last Post 3 mar 2011, 12:11 GMT-5
Posted: 1 decade ago 10 nov 2010, 06:55 GMT-5
I use 3.5a and my script sounds like this one:
h = postplot(fem,...
'partstart',A,...
'partmasstype','massless',...
'parttvar','partt',...
'partdata',{'u','v'},...
'partedgetol',0.001,...
'outtype','postdata');
position{d,1}(1,:) = h{1,1}.p(1,:);
% r-coordinate of the points along the pathline
position{d,1}(2,:) = h{1,1}.p(2,:);
% z-coordinate of the points along the pathline
J
I use 3.5a and my script sounds like this one: h = postplot(fem,... 'partstart',A,... 'partmasstype','massless',... 'parttvar','partt',... 'partdata',{'u','v'},... 'partedgetol',0.001,... 'outtype','postdata'); position{d,1}(1,:) = h{1,1}.p(1,:); % r-coordinate of the points along the pathline position{d,1}(2,:) = h{1,1}.p(2,:); % z-coordinate of the points along the pathline J
Posted: 1 decade ago 1 mar 2011, 20:48 GMT-5
Jacopo,
would you please specify more clearly the meaning of the parameters you have inside the script? I tried, but the parameter 'h' is unknown. Don't know where it came from.
Thanks a lot.
Pete.
Jacopo, would you please specify more clearly the meaning of the parameters you have inside the script? I tried, but the parameter 'h' is unknown. Don't know where it came from. Thanks a lot. Pete.
Posted: 1 decade ago 1 mar 2011, 21:10 GMT-5
Nevermind, I found a different piece of discussion where I found the rest :)
Thank for info anyway :)
Kind regards,
Peter.
Nevermind, I found a different piece of discussion where I found the rest :) Thank for info anyway :) Kind regards, Peter.
Posted: 1 decade ago 1 mar 2011, 22:35 GMT-5
Hello Jacopo,
at last, I encountered a problem with your script and still cannot find a suitable solution. I have also found the more detailed version of your script you prepared for Marie 'marie_comsol.doc' but in the line where:
seems to be a mistake, because this parameter is for a particle movement equation and MATLAB also prints an error.
Furthermore, when using e.g. 'partdata',{'partq*Ex_emdc','partq*Ey_emdc'},... the variable h = postplot(....) does not contain any usefull numbers, it's just a vector 148x1.
Would you explain this in more detail to me please ?
Thank you for your help.
Peter.
Hello Jacopo, at last, I encountered a problem with your script and still cannot find a suitable solution. I have also found the more detailed version of your script you prepared for Marie 'marie_comsol.doc' but in the line where: 'partdata',{'u','v'},... seems to be a mistake, because this parameter is for a particle movement equation and MATLAB also prints an error. Furthermore, when using e.g. 'partdata',{'partq*Ex_emdc','partq*Ey_emdc'},... the variable h = postplot(....) does not contain any usefull numbers, it's just a vector 148x1. Would you explain this in more detail to me please ? Thank you for your help. Peter.
Posted: 1 decade ago 3 mar 2011, 12:11 GMT-5
Here I am,
sorry for the late reply.
Can we do it step by step? Is quite some time I'm not using that script and I have to recall the different pieces.
But first: the command h = postplot... means that I'm performing a postplot action and all the data are going to be inside h. In my particular case the action was a particle tracing, and in the location h.p the positions of the particle were stored.
Now... tell me what you need :)
J
Here I am, sorry for the late reply. Can we do it step by step? Is quite some time I'm not using that script and I have to recall the different pieces. But first: the command h = postplot... means that I'm performing a postplot action and all the data are going to be inside h. In my particular case the action was a particle tracing, and in the location h.p the positions of the particle were stored. Now... tell me what you need :) J
