Conservative strategy on domain
After forming a union in the geometry, comsol sometimes gives the message of "Using conservative strategy on domain" or "Warning: Low minimum element quality". What do these messages mean? Can I just ignore them?
Thank you very much
Shujun
2 Replies Last Post 2 nov 2016, 10:49 GMT-4
Hello Shujun Xian
Posted: 9 years ago 2 nov 2016, 04:07 GMT-4
same question
same question
Posted: 9 years ago 2 nov 2016, 10:49 GMT-4
The message “Using conservative strategy on domain” appears in the log when the ordinary algorithm for the advancing front triangular mesher fails. The software then falls back to a different algorithm. This message is a notification. You can ignore it if things are otherwise fine in your model.
The message “Using conservative strategy on domain” appears in the log when the ordinary algorithm for the advancing front triangular mesher fails. The software then falls back to a different algorithm. This message is a notification. You can ignore it if things are otherwise fine in your model. Best regards, Jeff
