what is the different of 'form an union' and 'form an assembly'?
in the Geometry setup, The Finalize node ends each geometry sequence. In the Model Tree, its label is Form
Union or Form Assembly depending on its settings. but is there anyone knows what is the different?
2 Replies Last Post 23 nov 2015, 14:47 CET
Posted: 1 decade ago 7 nov 2010, 11:30 CET
the default union mode groups and slit all geoemtric objects such that all interiour boundaries are unique and by default set up a continuous BC on these interiour boundaries.
The assembly mode (nothing to do with CAD assembly, what in COMSOL is called a composite object) groups the composites objects, or separate objects such that they remain with their respective boundaries, this means that you can end up with overlapping entities or dedoubled overlapping bouundaries.
Assembly mode is used particularly for contact physics, and if you want to add physics on the boundaries (that oerlap)
Hi the default union mode groups and slit all geoemtric objects such that all interiour boundaries are unique and by default set up a continuous BC on these interiour boundaries. The assembly mode (nothing to do with CAD assembly, what in COMSOL is called a composite object) groups the composites objects, or separate objects such that they remain with their respective boundaries, this means that you can end up with overlapping entities or dedoubled overlapping bouundaries. Assembly mode is used particularly for contact physics, and if you want to add physics on the boundaries (that oerlap) -- Good luck Ivar
Walter Frei COMSOL Employee
Posted: 10 years ago 23 nov 2015, 14:47 CET
Regarding Form Union & Form Assembly, you will find this knowledgebase helpful:
www.comsol.com/support/knowledgebase/1216/
Hello, Regarding Form Union & Form Assembly, you will find this knowledgebase helpful: http://www.comsol.com/support/knowledgebase/1216/
