Do Cut Point 2D after a parametric sweep computation
Posted 4 nov 2010, 17:22 GMT-4 3 Replies
comsol version 4.0
1. Define a parameter in Global Definitions, for example "h", and during definition of the Geometry, "h" was used
2. Add Parametric Sweep in Study, and the parameter is "h", the values are h1, h2, and h3 for example
3. After computation, in Results --- Data Sets, I add three Solutions, Solution 1 corresponding to h=h1, Solution 2 corresponding to h=h2, and Solution 3 corresponding to h=h3.
4. After step 3, I add three Cut Point 2D under Results --- Data Sets, and Cut Point 2D 1 corresponding to Solution 1, Cut Point 2D 2 corresponding to Solution 2, Cut Point 2D 3 corresponding to Solution 3. After inputing the Point Data (I used expressions contain "h"), I press the plot button, but a problem occured, i.e. Cut Point 2D 3 can be drawed, but Cut Point 2D 1 and 2 cannot be drawed. It was so strange! I doubted the previous values of "h" were converd by the last value, is it true?
3 Replies Last Post 5 nov 2010, 14:33 GMT-4
