multiple integral
hi to all
i want to calculate the following integral. how can i do it?
plz see the attach file.
in this file h is the variable and not important for me.only it is important for me the calculation of it
thx
3 Replies Last Post 6 nov 2014, 20:22 CET
Posted: 1 decade ago 2 nov 2010, 07:28 CET
If I understand you correctly, you have a 2D model (x,y) with a variable "h" and you need the integral as stated, for me you define over the desired domain a domain integration operator "intop1()*", and then in a Results Derived Value Global evaluation analysis type in (in V4):
intop1(h^2)^2/intop1(h^4)
You can also define a variable H being equal to this equation
Did I understamnd you correct ?
Hi If I understand you correctly, you have a 2D model (x,y) with a variable "h" and you need the integral as stated, for me you define over the desired domain a domain integration operator "intop1()*", and then in a Results Derived Value Global evaluation analysis type in (in V4): intop1(h^2)^2/intop1(h^4) You can also define a variable H being equal to this equation Did I understamnd you correct ? -- Good luck Ivar
Posted: 1 decade ago 9 dic 2013, 16:38 CET
Where can I find help on intop1()?
Posted: 1 decade ago 6 nov 2014, 20:22 CET
In the documentation of v4.4, see Definitions>Component Couplings>Integration
-DW
In the documentation of v4.4, see Definitions>Component Couplings>Integration -DW
