How to integrate heat pipes in a cylinder
Posted 18 mar 2016, 09:52 CET Heat Transfer & Phase Change Version 5.2 14 Replies
I am beginner with Comsol (Version 5.2) and I need to modelize a geothermal tunnel.The principe is to integrate pipes (serpentine) into the tunnel's walls (whith cylindric geometry) to absorbe the heat from the soil.I am in 3D model and I used "Serpentine Channel 3D Rounded" which are plane and I can't make them curved.
Attached a file containing schema of geothermal tunnel explaining more the principe.
Any one can help? Thanks in advance
Your work can best be done with the Pipe Flow Module (www.comsol.com/pipe-flow-module), which allows you to model curvilinear pipes as 1D entities, saving you memory and solution time.
These 1D curves can be created in a number of way, the most flexible options being "Parametric Curve" (When you know an equation for the curve) and "Interpolation Curve" (When you know the coordinates of a few points on the curve), and they can be embedded in 3D objects to represent the interaction of the pipe with its surroundings.
A couple of models that will help you get going are the following:
www.comsol.com/model/geothermal-heating-from-a-pond-loop-12167
www.comsol.com/model/cooling-of-an-injection-mold-12371
www.comsol.com/model/heat-recovery-system-for-a-geothermal-heat-pump-18529
But it seems complicate to create pipes around 12m tunnel diameter with "interpolation curve",in fact, I need about 90 serpentines and I can't found the equation of this pipes in the wall's tunnel .
I think about creating pipes in vertical plan where I can use array and copy, then to incurve it .What do you think Sir?
Attached the model of plan pipes that I created
One is illustrated in the attached file: you create a custom function to specify one period of the planar curve, then use an analytic function to "periodize" it, and finally you use a parametric curve to "wrap it around a cylinder".
Alternatively, you could build this geometry programmatically using the App Builder (or LiveLink for MATLAB if you have MATLAB): each straight segment and each curved segment is easy to draw with its own parametric curve, and then it's just a matter of doing a for loop.
But there is no file attached to your answer
I have another question.As you had seen, the pipes are incorporated in the tunnel's walls.For physics, I choose heat transfer in solid and heat transfer in pipes.The initial value in "htp" must be "the temperature of walls calculated in ht", but I don't know how to define it,what should I type in the initial value text field T2 in htp??
Thank you in advance
For the curved pipes, I do the same us you to create the function and then to make it periodic (I just changed the expression of the piecewise function) but there is this error when I want to plot the analytic one
" - Fonction: comp1.an1
Echec dans l'évaluation de l'expression.
- Expression: comp1.an1(x)
- Affichage: plot1 (Graphique sur ligne)
- Fonction: an1"
I can't found where is the problem can you,please, help me?.Attached the file that I created
Chaima
If you require further support from COMSOL, please contact the COMSOL support team at support@comsol.com or www.comsol.com/support .
Chaima
So I succeeded to draw the curved pipes whith the method that you explained to me, but some errors came and I can't solve them.I attached a file explaining them and the mph file.
Can you please help me?
Thanks a lot
Chaima
Suggested Content
- KNOWLEDGE BASE My Flux Calculation Seems Wrong
- BLOG How to Integrate Functions Without Knowing the Limits of the Integral
KNOWLEDGE BASE
How can I see the equations COMSOL is defining?
How do I implement a user-defined Multiphysics coupling? - BLOG Integrals with Moving Limits and Solving Integro-Differential Equations
- FORUM Heat Transfer in Pipes and Air
