Counting particles by inlet; Particle tracing in laminar flow
Posted 17 mar 2016, 11:24 GMT-4 Fluid & Heat, Results & Visualization Version 4.4 2 Replies
Hello Comsol community!
I'm simulating a simple 4-way intersection using the laminar flow module. Two streets are inflows and two are outflows. Thereafter I'm adding particles to each input flow with the particle tracing for fluid flow module to trace how many of the particles coming from inflow 1 ends up in outflow 1 and 2 respectively, and vice versa for inflow 2.
My problem is that I can only count the total number of particles in each outflow and I can't find a way to distinguish were each particle is coming form.
I would really like to do this without exporting to MatLab or similar since I plan on doing a semi-large parametric sweep over different intersection geometries and I don't want to fiddle around with MatLab scripts, counting particle IDs, for each case.
Thanks for any help!
Sincerely Linus Olofsson
2 Replies Last Post 18 mar 2016, 06:30 GMT-4
