Modelling Current Carrying Wires in COMSOL
Posted 27 ott 2010, 08:45 CEST 7 Replies
Can anyone tell me how I can build current carrying wires in COMSOL?
I am trying to build a rectangular loop of current in the x-y plane and calculate the resulting magnetic field. According to theory, in the x-y plane, the magnetic field should only have a z component (the sign of the magnetic field is determined by the direction of the current in the loop)
Is it possible to solve this problem using 2D space dimension in COMSOL, or is it necessary to use the 3D space dimension?
Thank you,
Kevin
Kevin
it is well dscribed in the doc, and you must decide which physicsapplication mode you want to use, it all "depends" (and on version 3.5 or 4 ?)
I am using version 3.5 of COMSOL. When you say it is well described in the doc, I assume the doc that you were talking about is www.comsol.com/showroom/documentation/model/131/
While I have found the people on the forum very helpful, unfortunately I have to say the COMSOL help files are very incomplete and difficult to follow.
I have attached the model I am working on. In this simplistic model, I only have one finite segment of current. However COMSOL is not giving me the answer I would expect, so I assume I am doing something wrong. The z-component of the magnetic flux density should always be 0 since the current is in the z-direction.
If you could give me any advice on what I am doing wrong in my setup, I would appreciate it.
Kevin
I was also referring to the documentation in PDF, I can only suggest to read it and several times as there is too much in there to catch it all in one go, even after 5-6 re-readings I find new ideas, explanations that help me. And there are several exercices well described to follow. Just as in the model library, "l'exercice fait le maître"
First of all, your model is *unphysical*. Unphysical models tend to generate either nonsensical results or non-solvable computations. You simply cannot have a steady-state current in a discontinuous line segment like that. Instead, you should be able to make this model work if you put the full square current loop in your model.
Second, both the symmetry and dimensionality of a problem depend not only on the problem's geometry, but also on its solution. From that perspective, it becomes clear that this is an inherently 3D problem. So you should put in the full square current loop and solve it in 3D.
If I remember correctly, from my ACDC courses, the current return can be done efficiently by extending the loop wire to the external boundaries and have the boundaries loop the current around, this is mostly my default geometry construction when studyingthis cind of ACDC cases.
Depending on how you do it you might end up destroying a symmetry, so it needs some thinking for each geoemtry and depending on what you want to solve. Still a 2D-axi simplified reprsentation is far quicker to solve, but if you want to build something more complex with coupling, often 3D is required.
Suggested Content
- FORUM Modelling coils as current carrying edges
- KNOWLEDGE BASE Wrong number of DOFs in initial value
- FORUM COMSOL Queries/Issues with Modelling Magnetic Fields from Current Carrying Wires
- BLOG Losses in Three-Phase Transmission Lines
- FORUM Electromagnetic forces on parallel current-carrying wires - Comsol example
