ERROR: Time derivative only allowed with respect to mesh time
Dear users,
I am trying to simulate a two-phase Darcy flow. But, I end up getting an error as follows:
-Expression d(comp1.c1.t)
I believe c1 is the fluid content which is supposed to change with time. But, I can't figure out how to fix it.
I'd appreciate any advice.
2 Replies Last Post 21 mag 2017, 05:21 GMT-4
Posted: 10 years ago 15 mar 2016, 13:55 GMT-4
I have also the same problem !
Replacing d(comp1.c1,t) by d(comp1.c1,TIME) is recommendation by others but I can not find where to do that.
Hope to hear from others soon !
I have also the same problem ! Replacing d(comp1.c1,t) by d(comp1.c1,TIME) is recommendation by others but I can not find where to do that. Hope to hear from others soon !
Posted: 8 years ago 21 mag 2017, 05:21 GMT-4
Hi Nhan,
Have you solved this error? If have, would you share the solution?
Guoyan
Hi Nhan, Have you solved this error? If have, would you share the solution? Best, Guoyan
