2 decades ago
18 ott 2010, 02:27 GMT-4
well if its static voltage, try the AC/DC electrostatics then you should select either dielectrics (virtually no current flow, or "electric currents" if you have conductors)
if you have a varying field/current flow, the quasi statics is better, and if you have a constant frequency i.e. 50Hz use modal analysis, this makes a modal development of the equations an ou do not need to solve explicitely for each time sequence, you use only te amplitude an the frequency (that you might want to vary)
i you are at high frequencies (wavelength of the order of the dimensions of the items then you must use the RF mode.
in anycase, try out several of the documented exercices because else you will be very confused about all the settings, it takes some time to get used to COMSOL as it covers almost ALL physics
2 decades ago
18 ott 2010, 23:13 GMT-4
Hi Mr. Ivar,
I've been looked several of model library and try it, but I'm not find yet the similar model library with my model.
did you been read the paper of Mr. Meshkatoddini from Iran?, He wrote about "Study of the electric field intensity in Bushing Integrated ZnO Surge Arrester by Means of Finite Element Analysis". He did it with Comsol, and my project so similar whit this paper, I also use Finite Elemen, but without the conductor inside it, this paper not detail, so, what do you think about the Aplication modes that Mr. Meshkatoddini used for his model?
(I found this paper in the proceedings of the comsol users conference)
Many thanks
Sari
Hi Mr. Ivar,
Many thanks
Sari
22 ott 2010, 00:53 GMT-4
anybody can help me found the complete paper of this journal?
17 apr 2011, 10:48 GMT-4
hi
(Alsalam Alaykom)
I access
www.sciencedirect.com
if the article is in this site I can help you.
you can send the name of the article to my email address.
shojaei.adel[at][gmail].[com]
then I will send you full text article.
hi
(Alsalam Alaykom)
I access http://www.sciencedirect.com
