Porous Media - High Velocity
Posted 17 feb 2016, 22:18 GMT-5 1 Reply
                                                    Hello
I'm doing a job that compares a 3D model with a 2D planning.
This 2D model is a ".dxf" file.
I was unable to remove the pores as if they were empty, but as obstacles.
I simulating the flow of a porous medium model by creeping flow method and steady state.
My input parameter is pressure.
When simulate the 3D model with values consistent with the experimental.
When simulate, with the same parameters, the 2D model, the input speed and output is 100 times greater than would result.
My solvers are Pardiso and Double Dogleg.
What I doing wrong?
Thank you
What I doing wrong?
Thank you
1 Reply Last Post 22 feb 2016, 06:14 GMT-5
