Electrodialysis process (Nernst planck application mode in Comsol 3.3)
Posted 12 ott 2010, 06:54 CEST 0 Replies
There are 3 application used in this model; 1.Fluid dynamic (Navier Stoke) solution is fed in y-direction (convection) and diffusion+electromigration in x-direction 2.Electrostatic 3.Nernst Planck. Firstly, I run for the first two application modes it can run and show the good result but when I add the last mode, Nernst Planck that relates about mass electrotransfer (ion move under electric field), the result can't show.
For my question,
1. I suspect that the boundary condition and subdomain setting I used in Nernst-Planck mode is appropiate or not.
the detail is in the attached file.
2. If I would like to model this process in recirculation process, I will define the outlet concentration of the 1st loop as the inlet concentration of 2nd loop << Do I think in the right way? and if it's ok for this solution how can I define for this problem
The mph file is in the attachment.
Thank you everybody for your help
Chatchai
Hello Chatchai Boonyarattanamongkhol
