Walter Frei
COMSOL Employee
10 years ago
26 gen 2016, 19:10 CET
Dear Richard,
You may find this article helpful:
http://www.comsol.com/blogs/tracking-material-damage-with-the-previous-solution-operator/
Best Regards,
10 years ago
1 feb 2016, 19:10 CET
Thanks Walter, I reviewed your link and I think this is what I need. I have some further questions.
I am wondering two things.
1. The previous solution and ODE&DAE features can be used to change parameters based on values from previous time step. In the example given, the emissivity was changed from E_undamaged to E_damaged if the temperature exceeded 60 degC. My question is can a material property, such as thermal conductivity, be changed from a function of temperature, to a different function of temperature? (These functions are interpreted from data but could be changed to analytical if necessary)
2. To change the emmisivity, logical statements were used:
the source term read...
emissivity-nojac(if(T>60[degC],E_damaged,emissivity))
which means if the temperature of an element exceeds 60C then emissivity should become E_damaged. I am wondering if I could include the elapsed time and the position of the elements in this logical statement. It would be something like if an element who's X-position is less than or equal to some function of time, AND the element's Y position is greater than equal to some constant, AND the temperature of that element is over 60C, then change some properties of the element.
Thanks a lot!
Thanks a lot!
