Post processing (particle tracing with mass) at micro scale..
I am unable to trace a particle's path at micro scale. But if i repeat exactly the same steps for the same geometry, after scaling it to meter scale ( and changing the parameters accordingly), i get a proper output.
In the former case, on clicking the 'plot', simply nothing happens. Not even an error pops up.
I am using COMSOL4 in 2D mode.
Plz help !!
3 Replies Last Post 22 ott 2010, 20:37 GMT-4
Posted: 1 decade ago 13 ott 2010, 08:52 GMT-4
I am also having Problems and can't use it on a micrometer 3D model.
Posted: 1 decade ago 13 ott 2010, 22:50 GMT-4
Could you please post your simple mph file here? So more people can have a look at it and solve the problem.
Plz help !!
Could you please post your simple mph file here? So more people can have a look at it and solve the problem. [QUOTE] Hi, I am unable to trace a particle's path at micro scale. But if i repeat exactly the same steps for the same geometry, after scaling it to meter scale ( and changing the parameters accordingly), i get a proper output. In the former case, on clicking the 'plot', simply nothing happens. Not even an error pops up. I am using COMSOL4 in 2D mode. Plz help !! [/QUOTE]
Posted: 1 decade ago 22 ott 2010, 20:37 GMT-4
I am having the same problem. (exactly same in a way it works when I use m for geometry scale and modify it)
Is this software error?
I am having the same problem. (exactly same in a way it works when I use m for geometry scale and modify it) Is this software error?
