Help with simulating condensation from a partially filled closed glass vial in a cold fridge
Hi!
I am having trouble with a condensation simulation. A closed glass vial at ambient temp is partially filled with 10 degC water. When it is put in a cold room with temp of 5degC, condensation occurs. I am trying to simulate the temperature change of the liquid and glass vial over time and see when condensation occurs.
I tried to do the comsol after the vacuum flask and condensation in electronic device examples but my results are no good.
Does someone have any advice? Do I have to assume convection in the liquid? Can I figure out condensation vs. time by just using the "moist air" categorization or do I have to do a phase change?
I attempted attaching my files, but it wouldn't work.
Tamara
1 Reply Last Post 2 ago 2017, 11:05 GMT-4
Hello Tamara Dib
Posted: 7 years ago 2 ago 2017, 11:05 GMT-4
Hi!
Tamara
Hey Tamara, am working on something similar and having issues also. I had good success modeling without condensation as the fluid as a solid (just conductive heat transfer in the water) and convection on outside of flask/cup. But once getting to the condensation stage am struggling with the different physics boundary conditions. Am starting with a moist surface for the glass and wet surface for top of flask/cup but moisture transfer numbers are not reasonable. Want to make a moist air condition around the flask but quickly run out of memory when making a block of 1m^3 around cup.
Any progress?
-Joseph
[QUOTE] Hi! I am having trouble with a condensation simulation. A closed glass vial at ambient temp is partially filled with 10 degC water. When it is put in a cold room with temp of 5degC, condensation occurs. I am trying to simulate the temperature change of the liquid and glass vial over time and see when condensation occurs. I tried to do the comsol after the vacuum flask and condensation in electronic device examples but my results are no good. Does someone have any advice? Do I have to assume convection in the liquid? Can I figure out condensation vs. time by just using the "moist air" categorization or do I have to do a phase change? I attempted attaching my files, but it wouldn't work. Tamara [/QUOTE] Hey Tamara, am working on something similar and having issues also. I had good success modeling without condensation as the fluid as a solid (just conductive heat transfer in the water) and convection on outside of flask/cup. But once getting to the condensation stage am struggling with the different physics boundary conditions. Am starting with a moist surface for the glass and wet surface for top of flask/cup but moisture transfer numbers are not reasonable. Want to make a moist air condition around the flask but quickly run out of memory when making a block of 1m^3 around cup. Any progress? -Joseph
