[structural 3.5]coupled analysis and simmetry conditions
Posted 22 set 2009, 08:56 GMT-4 6 Replies
I have built a structural model made of a thin blade (thickness=t=0.14 mm) and a test mass(t = 24 mm).The blade is connected with its lower edge in the middle of the upper surface of the mass. I have modelled the blade with shell module and test mass with solid module; at the end I realized the connection between the two items with identity pairs.
Now I have two problems: the first problem is that I didn't find the eigenfrequencies that i was looking for( the entire geometry is connected with a fixed constraint along the upper edge of the shell), the second problem is that I wasn't able to use symmetry condition.
Now i try to explain better
FIRST PROBLEM
first step: I made a validation of model, correct mass and dimension
I think that the problem is about a coupled field analysis because i realized also the same geometry using only shell (3D mass like shell of 24 mm thickness) and i find the correct frequencies(I can't use this results because this geometry is only a small part of a more complex geometry), but when i made the coupled analysis(solid + shell solver) i find wrong eigenfrequencies (error of about 20Hz or more). I have a doubt on my procedure to put boundary conditions. First i put conditions on shell, so i select in Multiphysics menu shell model, after i go to physics and, in boundary settings, I select the right surface(surface modelled with shell)and i insert its conditions. Now i have one question: when i am in shell module what do i do with the other surfaces(mass surfaces) in boundary settings? are they active in shell domain or not? I select active in this domain(but i put very weak properties, density of 1 and thickness of 0.0001 mm)because if i put them inactive in shell domain i obtain an error during the processing. I put the conditions also in solid modeule and after i launch the analysis, in solver manager i select tll the voices, solid and shell variables.
SECOND PROBLEM
I have always blade and test mass geometry connected with identity pairs, i launch eigenfrequencies analysis of the entire model and I find the frequencies(2.5, 46,67 ). My model has two symmetry plane so slice it and i analyze only a quarter of geometry putting simmetry plane conditions in physics menu. In this way i thought to obtain the same wrong frequencies but the analysis return to me frequencies of about 1300 hz and beyond. I have two symmetry plane so i put symmetry conditions on one edge and the surface of the shell, and after i put symmetry conditions also on two surface of the solid.I slice along two surfaces, so i divide also the line that reproduces the connection between blade and solid, my question is: could i put some symmetry condition also for identity pairs?
I hope that my explanation is quite fair to obtain an answer.
thank you
Luca
FIRST PROBLEM
SECOND PROBLEM
thank you
Luca
6 Replies Last Post 1 ott 2009, 05:17 GMT-4
