Spring actuator
Posted 17 giu 2010, 19:23 CEST 2 Replies
I intend to use COMSOL software to simulate two ultra small concentric springs, which share the same
deflection axis. Since, the COMSOL software is completely new to me, I was looking for someone who has experience using it since I am an electrical engineer not mechanical. Therefore, I have decided to try to ask in discussion forum. Currently, I am going through several tutorial examples, which work with no problems. Unfortunately, I have not found a similar tutorial, which I could exploit to use in my simulation. Basically, all I need, is to simulate two concentric springs which are connected at both their ends. One spring is made of SMA material and the other is compression spring made of music wire. At the begining both springs are compressed, then they are released which results in their elongation, then one of the springs pulls the other so they get into its previous position. I need to simulate the forces and accelerations. I have not found any tutorials on simulating compression springs and I am very frustrated. I am assuming the elastic cylinder approximation of spring will do the job, Can anyone send me a link on tutorial that would be close to simulating compression spring? thank you very much .
2 Replies Last Post 18 apr 2011, 11:15 CEST
