Edgar J. Kaiser
Certified Consultant
19 nov 2014, 22:28 CET
something must be wrong with the arrow surface plot. If you upload the model (delete the solution if it is too big) we could have a look.
Cheers
Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Cheers
Edgar
Edgar J. Kaiser
http://www.emphys.com
19 nov 2014, 23:17 CET
Thank you for your reply Edgar. Original file size was about 50MB and it did not change even I deleted the solution and mesh. Therefore I created another file similar to the original file. Please find it attached(3MB).
All I did was simulated the model and created a 2D plot with a potential surface and a arrow surface representing the electric field. (I used a cut plane on the zx plane.)
Thank You.
Thank You.
Edgar J. Kaiser
20 nov 2014, 12:57 CET
I modified your model according to your description, looks ok to my taste. You didn't send your model so I can't say what is wrong there.
I am trying to attach the modified model, but it doesn't seem to work.
Yes the attachment didn't work. You can send an email address by private message if you want and I will send the model this way.
Edgar J. Kaiser
www.emphys.com
Edgar J. Kaiser
Jeff Hiller
COMSOL Employee
20 nov 2014, 14:15 CET
Hello Saliya,
Check whether in the arrrow plot in your 3D cut plane you are plotting the _in-plane_ components of the E field. I suspect you are not.
PS: Usually, with simulations like these, you do not include the electrodes in the model: they are considered perfectly conducting and you know in advance that the potential is going to be constant in each of them, so you remove them from the geometry and only solve for the potential in the dielectric (i.e. you subtract the two blocks from the sphere). As a result you only need air as a material (no copper).
Hello Saliya,
20 nov 2014, 17:23 CET
Hello Edgar and Jeff,
Thank You for your responses. Jeff you were spot on. My plane was a xz plane and I was plotting x and y components on the plane(beginner mistake). Now that I corrected it, it looks the way it should be. That was a great tip to subtract the blocks from the sphere.
Thank You.
Saliya
Thank You.
Saliya
