COMSOL 4.4 cannot replicate a COMSOL 3.5 Model
Hi guys,
I refer to this model:
www.comsol.com/model/fixed-bed-reactor-for-catalytic-hydrocarbon-oxidation-257
This model was created in 3.5a. I loaded it in a COMSOL 4.4 version. Two physics came out; Transport of Dilute Species, and Heat Transfer in Fluids.
Then, I copied all the physics exactly, including all the variables, using a brand new COMSOL 4.4 file. However, this brand new file failed to see convergence. Whereas the 3.5a file which I downloaded took only a few seconds to converge.
Solver, meshing are identical (double/triple checked). Can anybody point out what's wrong?
3 Replies Last Post 25 ott 2014, 02:48 CEST
Posted: 1 decade ago 23 ott 2014, 06:47 CEST
Do not know your settings of your model,but i consider that tiny diffiences in default setting occur between version3.5 and 4.4,scrutinizing defualt setting may work ,I ever solve similar problem by replacing d(p,t) as d(p,TIME),good luck
Niklas Rom COMSOL Employee
Posted: 1 decade ago 23 ott 2014, 14:26 CEST
Works for me. I uploded a 4.4 version of the file, with an improved mesh. Mapped mesh was introduced after 3.5a.
-Niklas
Hi guys,
Works for me. I uploded a 4.4 version of the file, with an improved mesh. Mapped mesh was introduced after 3.5a. -Niklas [QUOTE] Hi guys, I refer to this model: http://www.comsol.com/model/fixed-bed-reactor-for-catalytic-hydrocarbon-oxidation-257 This model was created in 3.5a. I loaded it in a COMSOL 4.4 version. Two physics came out; Transport of Dilute Species, and Heat Transfer in Fluids. Then, I copied all the physics exactly, including all the variables, using a brand new COMSOL 4.4 file. However, this brand new file failed to see convergence. Whereas the 3.5a file which I downloaded took only a few seconds to converge. Solver, meshing are identical (double/triple checked). Can anybody point out what's wrong? [/QUOTE]
Posted: 1 decade ago 25 ott 2014, 02:48 CEST
Hi Niklas,
Thanks for the speedy response. I took a look at the model you have uploaded, and I observed a node named 'COMSOL 3.5a solution'. I surmise you have opened the 3.5a file and re-meshed it to convergence.
I apologize if I didn't express my case clearly. I was referring to re-creating the entire file, in a 4.4 environment, from ground zero. In any case, I have managed to achieve convergence doing so, albeit taking me a good 4 minutes.
Thanks again.
Hi Niklas, Thanks for the speedy response. I took a look at the model you have uploaded, and I observed a node named 'COMSOL 3.5a solution'. I surmise you have opened the 3.5a file and re-meshed it to convergence. I apologize if I didn't express my case clearly. I was referring to re-creating the entire file, in a 4.4 environment, from ground zero. In any case, I have managed to achieve convergence doing so, albeit taking me a good 4 minutes. Thanks again.
