time dependend and parametric solution?
is it possible to solve for parameters and time dependend at the same time?
I'd like to model a viscoelastic material and apply a pulsed force. How could I implement this?
Thanks in advance.
Sabine
2 Replies Last Post 22 apr 2010, 17:54 CEST
Posted: 2 decades ago 22 apr 2010, 13:54 CEST
I woul suggest that you take a look at setting the solver in transient mode and check the use of the the "Solve - parametric sweep" this will generate a series of files for each parametric step
Hve fun Comsoling
Hi I woul suggest that you take a look at setting the solver in transient mode and check the use of the the "Solve - parametric sweep" this will generate a series of files for each parametric step Hve fun Comsoling Ivar
Posted: 2 decades ago 22 apr 2010, 17:54 CEST
thanks. Yes, the idea sounds good.
But how can I access the data when I export the fem-structure to Matlab? (Unfortunately I didn't find anything about that in the documentation.)
And a further question: Did I understand it right, that if I use the parametric sweep, I will get the whole time analysed for each parameter step?
Then the single steps would be totally independed of the previous/next step, wouldn't it?
However I'd like to do the parameter - time combination, because I'd like to see the effect of the former parameter step to a new force pulse. Is this possible?
Regards, Sabine
Hi, thanks. Yes, the idea sounds good. But how can I access the data when I export the fem-structure to Matlab? (Unfortunately I didn't find anything about that in the documentation.) And a further question: Did I understand it right, that if I use the parametric sweep, I will get the whole time analysed for each parameter step? Then the single steps would be totally independed of the previous/next step, wouldn't it? However I'd like to do the parameter - time combination, because I'd like to see the effect of the former parameter step to a new force pulse. Is this possible? Regards, Sabine
