Global evaluation of ewbe.beta_1 gives same value for all rows (solutions).
Posted 4 set 2014, 08:29 GMT-4 Version 4.4 3 Replies
I've solved the boundary mode analysis for port 1 like in the "Directional Coupler" model but with the addition of two parametric sweeps (wavelength and dimension).
Now I want to extract the effective mode index for all solutions, so I try making a Global Evaluation but the parameter ewbe.neff (or similar) does not exist as I was hoping so I figured that I could calculate it from ewbe.beta_1/(2*pi/wl) where "wl" is the wavelength parameter. However, the values are the same for each row (or solution) part of the table is shown below:
dimension, wl, solution 1, soution 2...
1.5e-6, 1e-6, 2.21885, 2.21885
1.5e-6, 1.64286e-6, 1.92064, 1.92064
1.5e-6, 2.28571e-6, 1.49211+1.64531e-10i, 1.49211+1.64531e-10i
It seems "ewbe.beta_1" is not updated for each solution of the parametric sweep but only for the different values of dimension and wl in the parametric sweeps.
Maybe there is an even easier way of getting the neff for each solution.
3 Replies Last Post 9 set 2014, 15:42 GMT-4
