COMSOL save file after study
In COMSOL 4.4 GUI, is there any way of saving the file after a particular study is completed ?
For example, in COMSOL Batch mode we have the 'infile' and 'outfile' options which saves the output after a study onto a file name as specified in outfile option. Is there any similar way of doing this in the GUI mode ?
The recovery file concept is absolutely of no use here, since it only saves the file before a study, not after it is completed.
Manyunat
2 Replies Last Post 23 ott 2014, 15:10 CEST
Hello Manyunat
Posted: 1 decade ago 22 ott 2014, 14:24 CEST
Manyunat
Hi Manyunat, it is really a good idea to have a save option in the study. We can make a suggestion to comsol to implement such an option. After the study completed optionally the solution could be saved a specified file.
[QUOTE] Hi, In COMSOL 4.4 GUI, is there any way of saving the file after a particular study is completed ? For example, in COMSOL Batch mode we have the 'infile' and 'outfile' options which saves the output after a study onto a file name as specified in outfile option. Is there any similar way of doing this in the GUI mode ? The recovery file concept is absolutely of no use here, since it only saves the file before a study, not after it is completed. Manyunat [/QUOTE] Hi Manyunat, it is really a good idea to have a save option in the study. We can make a suggestion to comsol to implement such an option. After the study completed optionally the solution could be saved a specified file.
Jim Freels mechanical side of nuclear engineering, multiphysics analysis, COMSOL specialist
Posted: 1 decade ago 23 ott 2014, 15:10 CEST
Hello. There is a store solution entry in the study portion of the model tree. This will save a copy of the solution inside your model at the end of the solve in a separate location. You can also do this manually with the copy solution command right in the same portion of the tree. Then you would need to save the entire model file with the usual file->save.
