Dynamic stiffness of rubber bushing with static pre-load
I am interested to model a rubber bushing and to calculate its dynamic stiffness (frequency analysis). The bushing is pre-loaded, which means it could have large deformations. Any good advice on which approach and module to use?
Thank you in advance for your time.
Regards
3 Replies Last Post 19 mar 2014, 03:37 CET
Posted: 1 decade ago 18 mar 2014, 03:38 CET
HI,
You should set up a Prestressed Analysis – Frequency Domain . That probably requires the Structural Mechanics Module. One challenge in this type of problems is to select a material model that has a dynamic stiffness (storage and loss moduli) that closely represents that of your rubber material.
HI, You should set up a Prestressed Analysis – Frequency Domain . That probably requires the Structural Mechanics Module. One challenge in this type of problems is to select a material model that has a dynamic stiffness (storage and loss moduli) that closely represents that of your rubber material.
Posted: 1 decade ago 18 mar 2014, 19:55 CET
Thanks for your answer. I guess that one of the issue is to, firstly, make the pre-stress, using some hyperelastic material (Mooney-Rivlin), and secondly calculate the frequency response using a viscoelastic material (Boltzmann's relaxation model). But what is the procedure to model a material in 2 steps (stationary and then frequency) and have a different material model for each step?
Regards
HI,
Hello, Thanks for your answer. I guess that one of the issue is to, firstly, make the pre-stress, using some hyperelastic material (Mooney-Rivlin), and secondly calculate the frequency response using a viscoelastic material (Boltzmann's relaxation model). But what is the procedure to model a material in 2 steps (stationary and then frequency) and have a different material model for each step? Regards [QUOTE] HI, You should set up a Prestressed Analysis – Frequency Domain . That probably requires the Structural Mechanics Module. One challenge in this type of problems is to select a material model that has a dynamic stiffness (storage and loss moduli) that closely represents that of your rubber material. [/QUOTE]
Posted: 1 decade ago 19 mar 2014, 03:37 CET
There is a pre-defined analysis type for this in COMSOL called “Prestressed Analysis – Frequency Domain”. Regarding switching materials between the two studies/steps it is possible and in some cases it is the most suitable way. However, you lose the benefits of the pre-stress analysis since the new material is no longer in equilibrium at the start of the frequency response step.
Nagi Elabbasi
Veryst Engineering
There is a pre-defined analysis type for this in COMSOL called “Prestressed Analysis – Frequency Domain”. Regarding switching materials between the two studies/steps it is possible and in some cases it is the most suitable way. However, you lose the benefits of the pre-stress analysis since the new material is no longer in equilibrium at the start of the frequency response step. Nagi Elabbasi Veryst Engineering
