                                20 ago 2013, 22:16 GMT-4
                                                    Hi Kwabena,
I wonder if COMSOL can handle the physical problem under nano scale.
                            Hi Kwabena,
                                20 ago 2013, 22:24 GMT-4
                                                    So how do I add a weak form of the heat transfer equation  to heat transfer model?
                                20 ago 2013, 22:27 GMT-4
                                                    Maybe a more realistic question is how to model a multisource heat transfer problem in comsol.
                                20 ago 2013, 23:41 GMT-4
                                                    Hi Kwabena,
Can you explain what is the multisource heat transfer problem?
                            Hi Kwabena,
                                20 ago 2013, 23:58 GMT-4
                                                    Say you want to solve the heat transfer in a domain with multiple point heat sources such that the heat generation term should be an algebraic sum of all the point sources.
Thank you.
Thank you.
                                21 ago 2013, 03:55 GMT-4
                                                    Hi Kwabena,
How large is the region with multiple point heat sources?
I don't know if COMSOL can handle the problem with seperate point heat sources.
                            Hi Kwabena,
