Using a Voltage waveform as an input in Comsol
I am studying the effect of lightning - induced voltages on the insulation of a medium voltage line. The induced voltage I am proposing to use, I obtained it from EMTP. I would like to know if I could add this voltage under the parameters instead of just a constant figure of say 300kV.
thanks Hunter
2 Replies Last Post 9 feb 2025, 18:03 GMT-5
Posted: 1 year ago 9 feb 2025, 13:43 GMT-5
Hunter,
a time dependent waveform cannot be a parameter. You must define a function (e.g. an interpolation function) and call it where you need it in the model.
Cheers Edgar
Edgar J. Kaiser
emPhys Physical Technology
www.emphys.com
Hunter, a time dependent waveform cannot be a parameter. You must define a function (e.g. an interpolation function) and call it where you need it in the model. Cheers Edgar
Posted: 1 year ago 9 feb 2025, 18:03 GMT-5
Hi Edgar, Thank you so much. I used the interpolation option and succeeded in calling it.
Thanks again, Hunter
Hi Edgar, Thank you so much. I used the interpolation option and succeeded in calling it. Thanks again, Hunter
