Step function that switches at derivative value
I am trying to define a step function for a parameter that changes when the time derivative of a variable changes (rather than at time = 0 or the usual use of step function). It only changes for one domain of the geometry. All other regions have a constant value of the parameter, e.
Here is the step function for the region:
e = { 0.06 if Vm' >= 0; 0.3 if Vm' <0}
So it will act like an On/Off switch basically as the value of Vm changes with the course of time.
1 Reply Last Post 13 set 2022, 19:36 GMT-4
Posted: 3 years ago 13 set 2022, 19:36 GMT-4
First define a step function that changes from 0.3 to 0.06 at 0. Let's say the name was Step1.
Then use Step1(Vm').
First define a step function that changes from 0.3 to 0.06 at 0. Let's say the name was Step1. Then use Step1(Vm').
