2 ago 2012, 19:25 CEST
From my understanding: if your plot did work before the update, then something did not update correctly, you should send your model or a reduced version, to "support" so they might find out what is going on, as we users do not really know everything under the hood.
Now depending on what your variable should show, you might still be able to plot by replacing the variable name by its formula, if you know that.
But be aware that some changes to the model cannot be done with only a "solution update", and might require a "full re-run"
3 ago 2012, 02:28 CEST
Dear Ivar,
Thanks for your kind reply! For in my own model, the same problem appears, and I cannot fix it. Then I come to the model library, the same problem exists. So I doubt that it is the problem of the COMSOL.
Best wishes!
Dear Ivar,
Best wishes!
3 ago 2012, 10:49 CEST
when nothing works, there is always "support" of COMOSL that can ;) Another way is to follow the COMSOL formulas (turn on equation view) you learn quite a lot like that
