Jeff Hiller
COMSOL Employee
3 years ago
13 set 2021, 10:53 GMT-4
Hello John,
If the two panels are glued together so that they behave like a single 9mm panel, why not model them as a single 9mm block?
Jeff Hiller
Hello John,
3 years ago
25 set 2021, 04:03 GMT-4
Hi Jeff,
It is because I would like to also simulate strips of glue bonding 2 panels together, not a completely bonded surface. The strips of glue would be thin lines running between the panels, and that is the setting I have trouble figuring out.
Cheers
Hi Jeff,
Cheers
Dave Greve
Certified Consultant
2 years ago
27 set 2021, 11:24 GMT-4
You need to know the mechanical properties of the glue. The glue needs to be a separate domain (or domains). Since the glue is probably thin you may need to use a swept mesh to keep the number of elements from becoming prohibitively large.
2 years ago
28 set 2021, 23:03 GMT-4
Hi Dave,
Thank you, that is a good suggestion.
Hi Dave,
